how can I use the same footer on laptop views (big screen) and mobile views ?
newwebsite.rplfrance.org : per example the footer here, although it is not finished, is not the same
looking at from a smartphone!
Note: I can’t do it from the Theme Panel, it is an imported cloud library theme…
Best regards
