Hello Mbclk,
Unfortunately, I do not understand very good on what you are referring to but if you want to have the save layout of our demo preview, you will have to install the demo or if you want to have the same layout of our demo you can add the default template from Visual Composer, like this -> http://screencast.com/t/M2XkwddOVwVs -> http://screencast.com/t/x7KaiZuIBc Please notice that the theme does not have such an option that offers you to import the .xml or .sql folder for demo content (layout), but only if you install them manually.
Hope this helps!
If is not what you mean, please provide more details in this regard, so I will be able to provide a more accurate response.
Hi, thanks for your answer, but it’s not what I meant.
What I need is a file for importing into my wordpress with everything that has the theme demo (images, content and estructure).
In other issues I downloaded, there is a sample .xml to import, and thus the configuration of the issue is much simpler.
Hello Mbclk,
Unfortunately, we do not have .xml file that could be imported via WordPress, sorry! Please notice that if you want to have a demo, the single way is to install it from WordPress, Demo section like this -> http://screencast.com/t/aqzU44ceqX
