Scaling problems
Hi guys,
I got two questions.
1) How to scale theme little bit smaller. Example compare pages http://ga-ga.com/gogaga/lifestyle/ and http://demo.tagdiv.com/newspaper/, the first one is smaller than the last one.
2) When I´m adding article photos WP automatically crops those photos and that´s why only the photos 750×400 are working. So, is there anyway to add photos example. 300×300 without cropping?
Thank you in advance.
Hi, my Ga-Ga.com site is running “NEWSMAG” theme from TagDiv and NOT running “NEWSPAPER” theme – smaller width layout, is the difference between the themes, while Newspaper 4x is more widescreen for all modern responsive layouts.
You can place images in your posts at any size and they are not cropped. Only the thumbnails used with featured image on various layouts are cropped to fit that layout/module. So, if a module has a 300×250 image to fit that layout, and you use a 300×300 feaured image, it is cropped to 300×250 for the module, otherwise if you had three images different size, they would not line up. 🙂
