Hello, I’m going crazy here. Can’t find an option that I figure should be here.
How do i change the default block color style in Scandal?
In Theme Panel > Block Settings > Block Predefine Style, it appears Scandal is using “Style 4 – Yellow”. I want to use “Style 1 – Red”.
How do I change it? I want all those yellow boxes on the demo home page to be the red style.
Can’t find a global default option changer anywhere.
Most of the color options on that demo are using the general accent color from the theme panel- https://i.imgur.com/mSOzhX7.png
I hope this will help you!
