Schema error for product review
Hi, I tried for the first time to add a review for a blog post to see how it goes and looks both on-page and on google meta.
I’m not using tagDiv blocks, I do use Gutenberg editor. Here is the screenshot of how I added it.
Just a few days after it has been crawled by google again, I got an error in the search console about the “aggregateRating” which is missing in the schema.
It shouldn’t have been automatically added?
Here is the post link!
Search console screenshots here
https://ibb.co/XCKBW0V
https://ibb.co/8m7TtyT
https://ibb.co/Cvhwckf
Please check this topic -> https://forum.tagdiv.com/topic/please-fix-the-review-schema/page/2/
Please deactivate the tagDiv Composer and tagDiv Cloud Libra plugins, delete and re-install tehn again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc and after go into the theme files in those paths -> wp-content/plugins/td-cloud-library/state/single/tdb_state_single.php -> wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php and uncomment those lines of code -> https://i.imgur.com/ZbzhdAm.png -> https://i.imgur.com/HrqwKjQ.png
Perfect …. works
