Hi there,
After this latest update to version 3.9 I have an issue with search and breadcrumbs.
1. With the search the drop down option of related articles work but if I hit the search or return The resulting search page is blank with no returned results? Also I have a BG Image set but this is gone. For an example look at: http://coconutoilpost.com/?s=fats
2. With breadcrumbs the pages work but I have permalinks set to category / postname. The new breadcrumbs does not reflect this?
3. If I use the booster plugin the BG images dont work and the next article in the drop down also stops working.
Can you please advise.
Regards
Peter
1. You have some JavaScript errors and 408 and 520 errors in the console http://screencast.com/t/Y7DDMxVs http://screencast.com/t/AWedht6aRJG
2. There have been some issues with breadcrumbs in this last version of the theme but those issues have been fixed, sorry for this.
3. Please disable all plugins, enable only the theme required plugins and the speed booster plugin and check if you still have this issue.
Thank you
Hi Lucian,
I turned off all plugins and still have the same issue. Also Media Bakery is now showing to update to Version 4.2.3 This site has Version 4.2.1 ?
When I activate tagDiv speed booster version 2.2 The search feature and navigation scrolling work as well as the BG Image but if I do a search I get a completely Blank whit page. The same happens if I select a tag.
When you say the breadcrumbs have been fixed do you mean there is another update? The current version I am on is 3.9 and the breadcrumbs for categories is broken. I have them active in the admin but they dont show when selecting a specific post ie. all I see is Home > Post name ?
Regards
Peter
Peter.
can you give me a link to your category page, I see on our demo that the category breadcrumps are working fine : http://screencast.com/t/dX0moiBJP
Thanks for you message.
Radu A.
Hi Radu,
Thank you but breadcrumb categories is not working for this site. Just try any post as they are all connected to a category: http://coconutoilpost.com/coconut-oil-benefits/mysterious-health-food-coconut-oil/
Regards
Peter
Hi, same problem here; in all posts breadcrumps are: Home > Post name (missing category).
Do you know how you solved it?
Some more info:
– theme version is 3.9.1, new installation;
– in homepage breadcrump is Home > Blog;
– if I add Yoast SEO code for breadcrumps the category name appears;
– i also tried deactivating all plugins (including one to remove category base from permalinks); same thing as Peter happened: WPBakery is now showing to update to Version 4.2.3.
You can fix it like this: http://screencast.com/t/TARPJIYeTGvE
About the Visual Composer, it will be updated in the theme update.
