Search bar problem!!!! Help please
Hello! Please help me what is the problem after the update, my search bar and dont worken the fade effect under the post title. I make one scr.
before my page and after my page.
thank you!!!!
I can’t access your screen http://screencast.com/t/0lI6TChRySlB so please provide a new link where I can see the image.
Try to deactivate all plugin except Visual Composer, clear all caches and also check the if the css from custom css affect search bar style. Inspecting your site I’ve noticed that you have lot os css in theme panel ant this may affect some of theme’s elements.
