this update is a disaster, the internal search engine does not work.
the problems encountered to date are:
– search engine does not work
– impossible to change FOOTER
– skipped all ADS – LOGO – LICENSE data
website :
http://www.debuglies.com
If you referring to the search from your website seems to work well -> https://www.screencast.com/t/mq1dwnjkiRas
Also, for the footer I saw you have a standard template, for this please make sure you have activated the tagDiv Standard Pack plugin (from version 10.4, the tagDiv Standard Pack plugin is no longer required because the new demos are using cloud templates)
I’m sorry, but I don’t understand exactly what you mean by ” m– skipped all ADS – LOGO – LICENSE data”, Can you provide more details?\
