Search engine fail
Hello
I noticed that till the 2 last updates, the search engine didn’t work well.
When you search for a word for example japon, you have instantly result (that is very GREAT) BUT all the links send to the category page of the article and not to the article itself.
Any idea how to correct that?
Regards
http://www.virtualmagie.org/
Please disable all plugins except of Visual Composer, clear cache and purge your files if you use CDN and check if you still have this issue. Also disable any js/css minifications. I did not found any issues with this using latest version of the theme with plugins that come with the theme’s files, also you can check our demo.
I just did that.
All deactivate, no cache plugin is installed and still not working! 🙁
Why?
sorry I have to reactivate part of plugin to continue to work on it.
If a member of Tag team want to test in admin, please contact me and will give you access.
Regards
Please send an email at contact@tagdiv.com and provide wp-access so we can take a look, also paste a link to this topic so we can know who you are. Also please disable CDN and see if you still have this issue or provide access so we can disable it when we will check your site.
Hello
I have no CDN.
Here a link :
I just send you the email with the admin info.
Replied via email!
P.S. This sounds like the same issue as the one I had (https://forum.tagdiv.com/topic/possible-bug-2/), which was successfully resolved.
Yes, it was the same issue and it is added to our list. We will fix it as soon as possible.
