Search Icon problem
hello, even after updating to version 8.5.1, the search icon on the menu bar is decentralized.
Please try and clear all caching installed, and purge CDN files if you use it.Then check if the issue is solved. Let us know if there still is a problem.
Hi, I also have the same search icon issue. Purging the Cache files didn’t fix the problem for me. Help me please!
@ganybhai
Please provide a link to your website so we can inspect the issue, if there is still a problem with the search.
