search problem
I enter the news, but I search in the searc section it says no results found, what does the tag, meta title search do? how can i activate
I have the same problem, also I do not appear in the search results articles two or three days prior to being published
Hello !
Please provide a link to your website in order to inspect and see what can be done.
The problem with search results page: this situation can appear when is set an offset in the cloud templates, please edit it with tagDiv Composer and check if there is an offset on posts loop element -> https://imgur.com/WE37H6O -> https://i.imgur.com/1csC6yd.png
Also I think that the same is with the cloud tag page, edit it -> https://i.imgur.com/INApxkC.png -> make sure that you remove the offset number and let an empty field -> https://i.imgur.com/URofmxX.png
Hope this will help you!
bahsettiğiniz şekilde bi sorun yok buluttanda almadım ? bu arada licansıı düzenlemek için sayfama gireceksiniz bunuda halletseniz
Hi Ali147, unfortunately I do not quite understand the last part, can you please provide some more details.
I took care of the problem as you say thank you
Hi, if there are other questions, let us know!
Have a nice week!
