Selection of posts for blocks
I have added a custom date field in my posts. Now I want to select to show only those posts for the blocks where this date is later than the current date. Is this possible by changing the code of the blocks?
Thanks for your help.
It could be possible but we have not tested this. We cannot provide a solution in this regard, sorry. We suggest hiring a developer/freelancer to help with the code as this represents customization which falls beyond what the theme support can offer you.
If you say it might be possible. Can it be done through using the queries in the file td_data_source?
Hello Mholzi,
Please keep in mind that as you want to achieve it is possible through the code and if you have solid knowledge in coding. Notice that task involve some additional customizations and we cannot provide this type of services at the moment, sorry! Notice that everything is possible through the code. So, if you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide this type of services at the moment, sorry!
  • This reply was modified 9 years by Mholzi.
