Hi guys.
I have an Problem. I build a new Website Layout.
I’m almost done and now I see that my SEO plugin showing the tagdiv code from the editor …
Why is code displayed there and not the content. How do I solve the problem?
That of course also means google and co. index the content like this.
https://s20.directupload.net/images/210606/25d78rve.jpg
https://s20.directupload.net/images/210606/m9tj38fg.jpg
If you have installed the last theme version10.4, please do these steps
1. disable all tagDiv plugins
2. uninstall all tagDiv plugins
4. re-install all tagDiv plugins again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
5. activate all tagDiv plugins
Please let me know the results.
thanks for your answer.
The problem is, the installation is a new and first installation.
I don’t use any cache plugin.
What should the content of the editor actually look like?
You need to hit the button “TAGDIV COMPOSER” and it will take you to the front-end where you can make changes.
This a video on how you can use the tagDiv Composer https://forum.tagdiv.com/tagdiv-composer-tutorial/
Also, you can check our channel https://www.youtube.com/user/tagdiv that can help you to design.
This is the way that our theme builder is working. Using tagDiv Composer you can build pages and cloud templates and this is done on the front-end where you will see exactly how the website looks when you add elements, but in the back-end, those pages and cloud templates are builder using shortcodes. That is why when you open a page in a WordPress editor it is displayed only shortcodes.
In order that your SEO plugin to identify words on your page, you can set the text in column text or in the text with title =>https://www.screencast.com/t/NsyYy3VHXQd
