Serif fonts not displaying on Androids
Hi, my Newspaper theme site is designed with some serif fonts. When I view my site on an Android phone, all the serif fonts are converted to Roboto (sans serif).
Please check if you use the mobile theme plugin, if yes, you need to set the fonts from Theme Panel -> Mobile plugin -> Theme Fonts => https://www.screencast.com/t/kjMkM15AKpOM
Hope this helps you!
I’m not using the mobile theme plugin. I have “gourmet pro” installed but made significant changes. Not using mobile theme plugins. and serif fonts not showing.
Please select the viewport on phone and change the fonts from the Style tab => https://www.screencast.com/t/DkvrfNlOS76
If it is a problem, please send a link to your website.
