Serious problems viewing/scrolling articles newspaper 12
Good evening,
I purchased and installed a second license of the newspaper 12 theme.
when I enter an article and scroll, there is a very serious scrolling error. Text and various graphic elements overlap, preventing correct display.
example:https://www.debugliesintel.com/bridging-the-command-gap-revolutionizing-u-s-european-command-for-modern-warfare/
you can check by scrolling down the article and then scrolling up… the writing and lines overlap… impossible to use!!!!
site: debugliesintel.com
you can check by scrolling down the article and then scrolling up… writings and lines overlap… impossible to use!!!!
I await your quick solution or theme update
tnks
I found the solution to this bug…because it is a bug….there are problems with the layout..when more than one column is selected it creates the problem…in the format setting of the article page..!!!
Can you please provide an example of where you’ve added the column? Let me know so I can check the issue.
Goodmorning
This is the link
https://app.screencast.com/aY5ikcea9nXom
what i did is remove the banner and chose the one column layout… and the problem disappeared!!! but it’s not good… is a bug
If you want to have two columns, I can look to see what caused the issue there and try to help you.
Please get in touch with us via email at contact@tagdiv.com and provide the following:
– admin URL and credentials
I will check and try to help you as soon as possible!
