Hello, is is possible to have the Pages use the same exact sidebar style/position as the Posts? So that the sidebar is up higher like the Posts? Right now on the Pages the sidebar is down under the title. On the Posts it is up higher above the title.
http://new.expatsinmexico.com/expats-in-mexico-video-gallery/
Hello saldesign,
I have inspected your website and I saw that your sidebars used for pages and post pages are the same. So, if you want to respect the order to them in the post page to look like on the page, you should change the post template and use, for example, the post template style 8 which displays the feature image in the top of the post and the sidebar will fall down it, like this -> https://www.screencast.com/t/dpCUdNMqJ
If is not what you mean, please provide more details so I will be able to provide a more accurate response.
No, it’s when you set the template on a Page to “Pagebuilder + page title”, then create a 2/3 + 1/3 row, and add a widgetized sidebar on the right… That sidebar is way down low, not up higher like the posts.
I’m trying to get the sidebar added by using VC in a 2/3 + 1/3 row with template set to Pagebuilder + page title, to be as high as the sidebar that is on the default template, any post or page with “Default Template” selected.
Page with template set to Pagebuilder + page title and sidebar in VC row-
http://new.expatsinmexico.com/expats-in-mexico-photo-gallery/
Page with default template set-
http://new.expatsinmexico.com/about-expats-in-mexico/
I want every single sidebar to up high near the menu and match each other, not some low and some high.
