Set Post Offset?
Hi Guys,
Simple question:
How do I set the offset for my frontpage and categories to 5?
I am using the child-theme, so please send me the modification code of the php files.
Thank you 🙂
Offset is set in the visual composer for each module I believe.
You could also modify templates per the WordPress codex info, for the loop and use the offset function as found here:
http://codex.wordpress.org/Template_Tags/get_posts
Hi Christopher,
I don’t use the Visual Composer or custom pages. Just plain and simple WordPress category.php pages and index.php.
Thanks for the link, will give it a try!
Don’t forget to enjoy the weekend 🙂
Andre
Pff, this (info beyond the link) is way over my head. 🙁
I’ll wait for TagDiv support to tell me how to offset posts in my Frontpage and Category pages
TagDiv Support,
Just to be clear, I don’t use the Visual Composer and don’t have custom pages!
So I would like to know how to set the offset for my Frontpage (index.php) and Category (?.php) pages. That’s it 🙂
hi,
use Homepage – with article list template so see the offset input: http://screencast.com/t/CiGgqEdy
Thanks for you message.
Radu A.
