Setting a Loop Layout for home page
Hi community,
I’ve purchased the theme today and installed the Newspaper demo. But I can’t find a way to setup the home page to loop layout as seen here http://themeforest.net/item/newspaper/full_screen_preview/5489609 under homepage layout. Any tips/documentation would be helpful.
Thanks in advance
Your link points to the demo main page, if you wanted to point to another page please use the direct link – http://demo.tagdiv.com/newspaper/
The homepage templates can be installed with one click. Just create a new page and click on the desired template – http://screencast.com/t/uBnBp9NP – it will automatically load the page structure. You only need to configure each block to make sure it displays the content you want – http://screencast.com/t/LLcHknpY7Rk
You can check how to set this page as a homepage here – https://forum.tagdiv.com/homepage-how-to-build-and-set-it/ – there’s a video at the end of the documentation.
  • This reply was modified 10 years by Emil G.
is it possible to add the loop feature to a homepage without loop ?
Yes, just change the page template to Pagebuilder with articles – http://screencast.com/t/UDgbbDjJss5
