Hi Guys.
You’re probably already aware of this, but if you change the background color (Theme Colors -> GENERAL theme colours) the site is forced in boxed mode (td-boxed-layout). Even though you’re _not_ using backgrounds. Also there is no option to set the body-color (100% white is really annoying for the dark skin).
We are aware of this and we try to make users aware of this as well: https://forum.tagdiv.com/theme-colors-introduction/ (note at the bottom of the article)
The black version does not require a white background though. If you install the demo and leave it to default, you will see that the header and footer are full width and not boxed: http://screencast.com/t/BzhxghiHdA
You can see this on our live demo as well: http://demo.tagdiv.com/newspaper_black/
So there is no need to worry about a white background on the black demo.
If you do not want to have the boxed version, you cannot add a background to your site, except for the whole thing. There will not be 2 colors on your homepage as there will be only 1 container. The background color adds another container to the site a td-outer-wrap that will not be there if no color or image is set in the theme panel, so there can only be one background across the whole content: http://screencast.com/t/EO3LQxWBGGzZ
