Hi:
Where do I set separate sidebar widgets for Posts and the home page just above the global footer?
Right now the Newspaper Default is showing both on Posts as well as just above the global footer on the home page.
For reference, on your demo, http://demo.tagdiv.com/newspaper/, it is showing “most popular” and “recent comments”, and on posts and “ad” and “must read”. On mine both locations have the same widgets.
Website under development is http://www.redryder200.com/pacifcapaddler/
Mahalo,
Loren
Please read the doc s on how to set the sidebars for posts and categories: //forum.tagdiv.com/sidebars-tutorial/
For pages the sidebar has to be created using the page builder on a split row. You can use the widgetized sidebar element if you want to pull a sidebar from the widgets area on a page.
