Setting Sidebar position to "No Sidebar" is not working
I have my template set to the default template when creating pages. But when I try to remove the sidebar from a page by selecting No Sidebar it does not do anything. Do you have a way of removing a Sidebar from a page?
Additionally, I found that the sidebar appears when I hit publish. I cannot move the sidebar to the left side or no sidebar. Seems to be stuck on the right.
The sidebar settings in the page edit screen will have effect only if the page is built with the WordPress editor. If the page is built with the tagDiv composer for example, those settings won’t do anything.
You can edit the page with the composer and position the sidebar where you want it, or remove it. In the composer a sidebar can be a column resulted from splitting a row
– http://prntscr.com/nxv9ej
Elements can be added directly in the column, or you can use a widget sidebar element
– http://prntscr.com/nxvagq
If there is a problem, provide a link to where it is happening, and mention some more details about it, I will take a look. Let me know.
