I’ve some issue with title length in the sidebar of my website. I use “block 7” element and I noticed that sometimes the title are cut first, sometimes later. Sometimes on two lines, sometimes on three. It seems that there is no rule.
Is it possible to set a standard rule? Setting Min/Max for titles?
You can see an example here:
https://ibb.co/dSGXXz
Thank you in advance.
Hello Evecta,
Notice that our theme has a functionality regarding on title length which can be set up from Theme panel, from here -> https://www.screencast.com/t/tQd628wb according to your module used by you.
You could use some CSS to break the words
Before – https://www.screencast.com/t/ktnKkwAxys5G
After – https://www.screencast.com/t/eG2zPKjtj06
.td-pb-span4 .td_block_7 .entry-title a {
word-break: break-all;
This code will apply to all blocks 7 set in one column, it can be made more precise if needed.
