Setting up the display of Posts from different categories in blocks on the Main
1. How to set up so that Posts from one section are published only in one block on the main page of the site?
Screen
2. How to set up so that Posts from certain categories are displayed in the block on the Main Page? (only 3-4 categories)
Screen
  • This topic was modified 1 year by rusinborg.
1. For this you need to select each block from your website and use the filter tab to set the category articles you want there – https://forum.tagdiv.com/flex-block-settings-guide/ – https://i.imgur.com/vVTJoha.png
2. This is similar to point 1 you need to use the settings from the block. You can set the number of articles, to filter the articles, to short them .. all this can be done using tagDiv Composer and selecting the blocks – https://forum.tagdiv.com/flex-block-settings-guide/
