Setting Video Post has problem
The template error for displaying on the Video post, it would only display the captured image from youtube.
The video post function is working (template 10) on 23 Oct, 2015. When I updating my website this morning 24 Oct 2015 (Hong Kong (+8.00) time 11:00am).
The problem testing link: http://travels.media/a-tester/
The working link: http://travels.media/咖啡旅遊-德國街頭咖啡機秘密何在/
My website has doing the Cloudfare / Cache function. Please help to solve the issue.
If need any admin login, please feel free email me: trevorcheung@outlook.com
Please try it without any plugins. I see you use rocketloader, which is known to cause problems with our theme. Please disable all javascript, css and html minification options. Then disable all your plugins except visual composer and check your link again.
Let us know how it goes!
I have disable the rocketloader plugin, the video display effect still the same no improve. I also try disable cloudfare support, also no help.
I only can do is clone the old (video) post, then edit from that post. finally it’s work.
Please check the post format and set it to video – http://screencast.com/t/Kdsc0BQD09sEhttp://screencast.com/t/bHNDpp0Jprep
