I recently acquired a website with this theme and after the migration from server I see these issues:
td_api_base::mark_used_on_page : a component with the ID: single_template_7 is not set.
/var/www/vhosts/noticiasvideojuegos.com/httpdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_api.php
Display backtrace
wp_booster error:
td_api_base::get_key : a component with the ID: single_template_7 Key: file is not set.
Display backtrace
wp_booster error:
The path of the single_template_7 template not found. Did you disable a tagDiv plugin?
Display backtrace
wp_booster error:
td_api_base::get_key : a component with the ID: single_template_7 Key: bg_use_featured_image_as_background is not set.
Display backtrace
wp_booster error:
td_api_base::get_key : a component with the ID: single_template_7 Key: bg_disable_background is not set.
Display backtrace
wp_booster error:
td_api_base::get_key : a component with the ID: single_template_7 Key: bg_box_layout_config is not set.
Any ideas how could I sort it out? Currently I hided through css but I want to fix it…
Thanks in advance,
I think that after you migrate the website not all theme plugins are activated.
Those errors are because there are individual posts that have set the post template 7 and this is coming from tagDiv Standard Pack plugin, please install it and activate it from Newspaper > plugins. After that the problem should be resolved.
Let me know the results!
