What is going on, Sharing button and related articles section is not working in my blog logicaldost.in
Please fix this issue
This topic was modified 7 years by
Pradeep Singh.
I was facing the same issues in my blog https://buddymantra.com/ you need to change the default post type to any cloud templates or any templates available. it will be solved.
I forgot to mention you need to add the plugin js_composer.zip manually and you will see the social sharing icon will appear.
where I can find the above plugin, and I use a plugin for that feature,
I think I made a mistake by choosing this theme
Hey Newspaper Support Team Where are you,
We are facing many problems in your latest update, if you can’t solve these problems then tell me how I can download the previous version of the Newspaper theme.
I have fixed this on page: https://forum.tagdiv.com/topic/like-button-desapared-after-update-v-9-7/
I tried to solve the code bug here: https://forum.tagdiv.com/topic/errors-in-the-new-version-9-7/#post-289833
If you can not fix the problem using the topics provide by @Viju and @ySV please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
