Short Code Columns Help
I know this might seem stupid, so please forgive. I’m trying to use the grid columns short code and it doesn’t seem to do anything. the “1/2 Columns” shortcode doesn’t divide anything up. I’ve tried it in text and visual. Other short codes work, like the block quote, box quote, etc. But not this one.
Here is a test example…. (see the first paragraph)
http://sinclairworld.com/sailingchancetest/?p=79
You can enable the Visual Composer on posts – http://screencast.com/t/Oq9quErhIj
Result – http://screencast.com/t/NILSSqCGG1 – http://screencast.com/t/IHmzCluu8Y
Thank you, Emil G.
