Shortcode not work On Mobile View
How Can I Add Sticky Social Share Button On Mobile View And Show Updated Date in Mobile Theme?
If I Use Shortcode
[tdb_single_post_share like_share_style=”style4″ like_share_text=”yes” el_class=”ajshare” content_align_horizontal=”content-horiz-center”]
[tdb_single_modified_date]
[tdb_single_reading_progress bar_pos=”top” bar_fill=”#8224e3″]
in Mobile Theme. it did not support it.
Even I Tried This Code
Share-Post-Shordcode
AND
Reading-indicator-Shordcode
  • This reply was modified 4 years by discovermh. Reason: img alt tag
Indeed, the mobile theme was made to remove the shortcodes, so the mobile version become faster.
If I’m right the code for this was implemented in this file -> wp-content/plugins/td-mobile-plugin/td-mobile-plugin.php
Also, you can display the modified date using this option -> https://i.imgur.com/6qotPb8.png
There is No Option Post Setting Under Mobile Theme
No Option
Current Version RC12 & V11.5.1
Same For Desktop View
No Option
If there is no option for the Post Setting Under Mobile Theme, then you have the tagDiv Standard pack enable, please disable it and the settings will be displayed.
