Shortcodes for home page demos
the update to the theme has broke my site but only the home page
Is there a way I can get the shortcodes for each homepage demo? where can I find those?
What did it break exactly and how? We could take a look if you can post a link to the website.
Most demo homepages are provided in the cloud library and can be imported
– https://cloud.tagdiv.com/#/load/Homepages
Or you could copy the homepage shortcodes from the tagDiv composer plugin files
– http://prntscr.com/nvepvb
Each demo has the homepage there, for example – http://prntscr.com/nvetip
I’ve restored an earlier backup till I can figure out what happened
I used the enveto plugin to update the theme. it said it updated fine but the front page was blank with no blocks.
I then clicked to edit in td composer and it said it was created with tg composer
Best to try and update by FTP, this is the most reliable and recommended method. Here is a guide if needed – https://tagdiv.com/update-newspaper-theme/
If you have a development copy of the website, test updates there first to see what happens. This would be better then doing it in the live website, in case something is wrong.
