Show dates in the posts of the main home page and the single posts
Hello I’m trying to put the dates in the unique posts and also in the homepage. The feature was working, but I turned it off in the theme panel but I am not able to enable the function again.
I enabled on the dashboard is not working on the theme.
please, can you help me?
http://www.schoje.com.br
I see the date is not appearing. Are you sure it is enabled here for posts here
– http://prntscr.com/mzi86z and here for modules – http://prntscr.com/mzi8i6
For the loop in the homepage also check if the date is enabled in it’s settings
– http://prntscr.com/mziblo
Let me know.
Hello, the settings of the posts and the blocks are correct. But the TAG DIV editor options do not have the Layout tab in block 16 that I’m using at home.
in the editing screen of the div tag editor in the initial page paigina I can see the date but the color of the letter is very clear, very blurred. then when saved it disappears on the home page.
Is it not because of the clear heart of the letters of the date ??
where can i change the date color ??
see my settings
https://schoje.com.br/wp-content/uploads/2019/03/blocstings.png
https://schoje.com.br/wp-content/uploads/2019/03/loopposts.png
https://schoje.com.br/wp-content/uploads/2019/03/modo-de-edição.png
https://schoje.com.br/wp-content/uploads/2019/03/postsetings.png
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Resolved ,Thanks
