This is the situation: my post title are accurate but very spcific (basically artist and record name); in order to engage more view the audience I’d like to use in the home page and in the content blocks the Subtitle instead, where I can write something more captivating for the casual reader.
It should work like this: if subtitle set, then show subtitle, if empty show title.
Or any other workaround would be great.
Thanks a mil
Subtitles of the posts will only be displayed in the actual post page, not anywhere else. Most modules display excerpts, these can be default excerpts or you can set theme manually
– https://forum.tagdiv.com/excerpts-introduction/
So you could create custom excerpts and display theme for the posts you want.
The post titles will be the ones you set when building the page, only those will be used on modules/blocks.
