I upgraded Newspaper 4 to Newspaper 6.4. I have now problem with “show post views”.
theme panel / post settings / post and custom post types / show post views on/off
If I turn it off:
– counter stopped working (post without views)
– post views do not show in wp administration
In Newspaper 4 it worked correctly.
Thank you
David
http://www.sportujeme.sk
Instead of disable it from Theme Panel > Post Settings, you can use custom css to hide it – http://screencast.com/t/jTdQJ0Dt6hgi
.single .td-post-views {
display: none;
Thank you. It works, but for a short time during loading, I can see the number. But it is better then before. Thank you.
