Show posts and events in blocks and grids
Hi!
I’m trying to put some posts and events in my homepage. I filtered the Categories and Custom Post Types that I want to show on the Big Grid and blocks, but events does´t appear on it.
The details about what I want to show:
– Custom Posts from categories 74 (post category) and 1874 (event category). I put these categories in Multiple categories filter box).
– Post & events (events are taken from Events Manager plugin) from these categories. I put it in Post type box.
Can you give some help in order to do it?
The tagdiv blocks were designed to work with default posts and also not sure if the Events categories will appear on block settings. You could try to filter by tags and see if it works.
