But in this scenario, the Author can put only Good Things Like
Best Content
Great Writing
Superb
From where we can edit the comment form only we want the name and Comment Section Only.
https://tinyurl.com/2ap5wxo6
Hello @shivangtomar!
The administrators create the criteria there. Unfortunately, there are no settings to add or remove a field from that form.
there will be a way from code {cpanel}, Please refer me that way that is important to remove extra fields from the comment form.
The code requires custom work, which is not covered by the support team. For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Thank you for understanding!
The Mod Security is in cPanel, so please ask your host or you can try to disable it -> https://i.imgur.com/bOUyM2U.png -> https://docs.cpanel.net/cpanel/security/modsecurity/
