Side bar is appearing below rather than alongside the posts
I have followed the instructions closely on setting up a template using cloud library but though the sidebbar widget shows up correctly on tag div composer when I view the sidebar adverts appear after the content rather than alongside.
I have set the column to 2/3 1/3 and even 1/2 1/2 but no luck
What could be the problem?
I think that this is a plugin conflict between tagDiv Cloud Library and WPBakery, you can use only one of them, you should decide which one you want to use, we recommend to use the tagDiv Cloud Library with tagDiv Composer these are the theme plugins.
Please deactivate the WPBakery and check the results!
Let me know the results!
Thanks. Problem solved
