Side by Side Ad Placement
Hi Thanks for your continuous support –
I would like to know how I can achieve this with the plugin:
http://www.screencast.com/t/vFs4obpq
http://www.screencast.com/t/7HlbzLT7UC
I have tried the code which I used with for the Ad Inserter plugin that I am presently using to achieve that -in the panel but it is not show like these when I use the internal theme spot for the ads.
I would want to know if there is any internal way within the theme to show deadlines as it is shown in the screenshot below:
http://www.screencast.com/t/pV4YAdtD
Hope to hear from you soon
The theme doesn’t have an option to display ads side by side, it can be achieved only with custom modifications, for example – https://forum.tagdiv.com/topic/how-can-i-place-two-ads-side-by-side/#post-66221
Also to change the default date view, you need custom modifications – https://forum.tagdiv.com/topic/changing-timestamp/
