Good morning,
I need help in several matters:
1. How tu add element “Column conntent” or “Image info box” to the sidebar in all single post? Is it also possible to add eg. “Column conntent box” to the end of the single post before the social share icons?
2. How to create this kind of advertising… appear only in mobile screen once at the top and once at the bottom? Are these maybe AMP ads?
https://www.screencast.com/t/wLtTn4Dgp
https://www.screencast.com/t/4k10QjFvt
3. When I browse the homepage with Internet Explorer the button in “Column conntent” element are not displayed text and icon. Also the same problem is with button in “Image info box”. In Chrome and Firefox works ok.
https://www.screencast.com/t/XhbvRoyU1gxo
https://www.screencast.com/t/neYhczBc
4. I created a table using the TablePress plugin. When I click on the bottom of the next page button I won’t see the rest of the table but the jump is down the page on the footer. How to fix it?
https://www.screencast.com/t/i7L1pcQR
https://www.screencast.com/t/krUaNzRV6pJ
Site live: https://inwestycjesportowe.eu/przetargi/
Regards,
Mario
1. The “Column content” or “Image info box” can be set only on single post template, you can get these template from tagDiv Cloud Library and you can edit it with tagDiv Composer.
2. These are some anchor ads ( these have the position set as fix), our theme do not have these options, this can be achieve only with some ads plugin or custom work.
3. Is possible that the internet explorer to not recognize the style that is set on that button. Please provide me a link to your website where I can check this problem.
4. This is an untested plugin, but from what I can see is working normal now -> http://prntscr.com/pyjegr -> http://prntscr.com/pyjem6
Good evening,
1. I use the default theme so if I want to add these elements I need to create a separate template for the single post – right? What about those already published?
2. Ok.
3. My website: https://inwestycjesportowe.eu/ I use on the homepage “Column conntent” and “Image info box”.
4. What I mean is that when I click the “next one”, it doesn’t show the position in the table, but it moves me to the footer. See this video:
https://photos.app.goo.gl/J52bSjUWdXZB1oR98
Thanks for the answers
Mario
1. Yes, you’ll need to import the single post templates from tagDiv Cloud Library, these will be apply on posts, so you’ll not create new posts, just new templates.
3. I do not see the problem, for me on the Internet explorer from W10 everything is displaying normal -> http://prntscr.com/pyyyip
4. Here is how is working for me -> https://www.screencast.com/t/fXxlI6qdgCiQ unfortunately, I don’t know why this is happen, this is untested plugin is possible that some code to interfere.
Ok, thank you for the answers.
I have one more question: how to remove a page title from a specific page? I’m using the default template. As I changed to page builder + page title, it didn’t work either. Maybe some CSS code will help with that?
https://www.screencast.com/t/AG0ZUSjIhk5
Mario
If you want to remove it from all pages -> http://prntscr.com/q1o2oe
.page .td-page-title{
display: none;
Thank you, the code works!
Last question: when I paste a Facebook post or video, there is a large empty space in the mobile version! How to enslave it?
https://www.screencast.com/t/7JqbSyPm2Hmm
Mario
