Hi, I really am having a hard time figure out how to make the columns look like the demo… that is, how to group up posts under small 4-box segments? Right now, I can only list them. How to make the side bar more along the lines of two-bar, with more posts?
My site is: http://www.twothirdsoftheplanet.com
Thank you
Please disable Photon module from Jetpack as I have checked your site and you have this issue – http://screencast.com/t/o0whpae5 We don’t recommend using that photon module as the theme works based on the same system so we suggest you disable it. Or if you use CDN try to disable it.
Regarding the columns please provide a screenshot from our demo – http://demo.tagdiv.com/newspaper/ as I’m not really sure what you mean.
