I made the page elements in the visual composer and I want to put those elements in the sidebar(https://www.pedagog.rs/proba-2 – I added these elements with shortcodes in the sidebar in custom html), but when a sidebar appears on some side, it does not look good (https://www.pedagog.rs/proba2). how to make the sidebar look the same as on the page https://www.pedagog.rs/proba-2.
Thank you
I don’t think I understand what the final result should be. On pages there is no need to use the HTML element to create a sidebar, that may not work properly as it can be seen. The sidebars can be created in the page with the elements you want using the chosen composer.
That will most likely not work properly, best you try and use widgets that are meant to be used in sidebars, instead of this solution. It would be hard and probably require a lot of
styling to make those broken elements display like in the page.
As it seems that you are using Visual composer, you could enable it for posts and build your posts with Visual composer
– https://www.screencast.com/t/wTkFK1x4gXHd
However using Visual composer on posts is not recommended, but if you require this functionality give it a try.
