I use a standard post template
on Pages sidebar & footer is ok
but when go to single post all sidebar & footer not like when editing mode
Editing Mode (No Issue)
https://ibb.co/xJx3rDg
View single post
https://ibb.co/qnBXYvP
https://ibb.co/wgW3k0X
Hi, this is a cloud template https://imgbb.com/xJx3rDg not a standard/default template -> https://forum.tagdiv.com/design-post-pages-using-default-templates/
Usually the problem that you descried appear when you have a plugin conflict, for example when you are using tagDiv Cloud Library with WPBakery.
Please try only with theme plugins, if the problem persists, please provide a link where I can inspect the situation.
