Sidebar going to top on mobile
Website SneakerFiles.com/test
Hello, I am using a widget sidebar and for some reason on mobile, the sidebar contents go above he blog posts. Normally it should go below. How do I fix this?
Maybe you modified the page template files directly or in a child theme, please check if that is the case. In post pages it seems to work properly.
Also something unusual I am noticing is that the category pages seem to use the Newsmag theme, while the posts and rest of the website uses Newspaper.
Hmm that is weird because I didn’t mess with the child theme. Only thing I plan on doing is adding the CSS to it.
Is there a way to fix the two? If I made the sidebar inline, could that of done it?
I think I found out the problem here. This block – http://prntscr.com/mo2rro is hidden on mobile, check it while editing the page with the composer. Click on the block and select the mobile viewport – http://prntscr.com/mo3uzw then in the CSS tab it may be hidden
– http://prntscr.com/mo3vdr
So the block will be hidden on mobile, and the column on the right will take it’s place.
Lower in the page you have a block that is hidden on desktop – http://prntscr.com/mo3wys
This is displayed on mobile. Please check all the blocks in the page in all devices
– http://prntscr.com/mo3xnt
This issue is caused by a combination of hidden blocks. Best to make them all display and redo your settings based on how you want the page to look.
Ok. I see. But is there a way to make the block stay the same on desktop (image left, title, excerpt) but on mobile it will be image and below title?
I think the category pages you saw using NewsMag is on the active website and not the demo (some of the links in the navibar will take you there
That is possible with a flex block, for example with flex block 1 make it look like this on desktop – http://prntscr.com/mojnsz and like this on mobile – http://prntscr.com/mojo3h
The layout settings can be different for each case – http://prntscr.com/mojoeu So the same flex block can look in four different ways.
