Hi guys,
yesterday all was good when looking at my articles, but today i see that the sidebar has changed position. It was on the right side of the post, but now is on the left and falls over the content.
See screen:
http://i201.photobucket.com/albums/aa183/Saikological/sidebar%20left_zps1d2rnrtt.jpg
My global settings are:
Default post template: style 2
Blog and post template: sidebar right (3rd option)
I dont understand why the sidebar is showing on the wrong side of the page, on each post.
As all my settings seem correct, how can i fix this?
This is a code that breaks the html. It can come from a plugin or custom code modification. Please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
thanks. ive tried disabling all plugins and found that the problem is caused by either the tagdiv composer or the tagdiv social counter. im figuring i dont need these two anyways, so ive kept them disabled.
