Sidebar issue with preset template for Simple Post
Good morning, I want to change template of “simple post” on my website. I choose a template from cloud library but I’ve many issues. Loading the template in the editor I encountered several problems, including the lack of the sidebar (with instead was in the preview).
Please provide more information about your issues, screenshots or a video, and your website link, so I can help you efficiently.
Hi Bettina. The website is GizChina.it
I choosed from the Cloud Libray the template “Single Post Template 1”. This one: https://cloud.tagdiv.com/50-tips-and-insights-about-productivity-happiness-and-life/
If you check the screenshot the sidebar is not available or it overlays to the page and Disqus is not showed. This issue affect all templates. In fact we can’t use Disqus and sidebar in each one.
Currently the Cloud Library template is not enable because for all these issues.
Sidebar is not available
Sidebar overlays the page
The problem with the sidebar is related to a plugin conflict between tagDiv Cloud library and an extra plugin, this plugin is WPBakery, this is overwriting the cloud settings for rows.
so to have the nice layout you’ll need to disable the WPBakery plugin, or use some custom css to adjust the css.
AS for the Disqus plugin, please use this one -> https://i.imgur.com/ekEVAVu.png
Hi Calin,
thank you! The sidebar issue is fixed when i disable the WPBakery plugin but the Disqus comments are still not loaded. We already use Disqus Conditional Load.
Disqus is not showed also with Disqus Conditional Load active
Please make sure you have set the Shortname and API Public Key -> https://i.imgur.com/znabONW.png
Hi Anamaria,
The shortname was already added. Now i added API Public Key but Disqus is still not loaded. I tried also to clear the cache.
  • This reply was modified 4 years by carmelo3m.
Disqus doesn’t save the API Key. Every refresh the field is empty
Settings before to save
Please check the console, maybe you have something which blocks the requests to save the settings.
