Sidebar not appearing in posts
Hello! I have a strange issue with sidebars on posts. When I select the Default or Style 5 post template, the sidebar displays with no problem at all and also the smart sidebar works fine. Look here: http://www.mizonadeportiva.com/2014/12/02/dos-gigantes-se-desafian-uno-al-otro/
But when I select any other post template the sidebar does not appear, it does appear at the bottom of the Post content and in the left (when smart sidebar is active the sidebar only appears when scrolling back to the top of the post).
I’ve already tried disabling all plugins, creating new sidebars and nothing works. I also did a correct update and also tried on Chrome, Safari and Firefox, they all display the same issue. Any help?
  • This topic was modified 10 years by jbenitez.
From that example, looks like the FB comments plugin is too wide breaking your layout ?
You can also try this without plugins. Please disable all of them except visual composer and check again.
(I suspect the buzz player ad. In posts where you do not have this ad, the sidebar displays fine.)
Thank you! The culprit was the eBuzzing player as you said, problem solved!
