Hello tmaghrebt,
I have checked your website and I saw that you are using some untested plugins which can interact with the theme core and cause a lot of unknown issues. Please try to disable all of them, leave just Visual cOmpsoer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins. Purge all the CDN files and check the results.
Hello tmaghrebt,
Please check your sidebar settings and the widgets from theme panel to have some elements inserted on your sidebar. Also, if the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer you setup page. Provide there the link of this topic so we can quickly identify you.
