Sidebar on Posts (Mobile) appearing at bottom – how to move ?
How do I move the position of the sidebar on posts? It is showing the content, then sharing buttons, then related articles. How do I set it so it loads like this;
1. Article
2. Enter Competition
3. Share Buttons
4. Related Articles
These changes involve a new page structure and are required some customizations in theme’s core files to achieve the desired result. Basically you need to edit the file corresponding with post template used and change the elements order: http://screencast.com/t/lVnKKMMVmf7f
Note that this task require basic codding skills in order to be achieved and if you’re not aware of the steps you need to take in this regard my advice is to look for someone who can help you with implementation as we can’t offer customizations services at the moment.
