If the sidebar is not apply on your posts, that is because you are using a single post template from tagDiv Cloud library, this can be edited using tagDiv Composer. What you can do to keep the template layout and to have a sidebar selected by you is to edit it like this -> https://i.imgur.com/jK8VGvX.png and use the right click to remove the elements you do not want, also if you have an sidebar made from widgets and you want to display it for posts, you can drag the element from composer and select the sidebar -> https://i.imgur.com/MkCuCRg.png -> https://i.imgur.com/S5hgJ9u.png or if you want to be able to set individual sidebars, then you need to use a standard post style -> https://i.imgur.com/L5q9aUK.png
