Sidebar problem
Hi there,
I’m trying to add a sidebar to my blog posts but it’s not working.
I’ve created a template where there is the blog post content on the left side and the sidebar on the right side and when I view the template it works perfectly. But when I apply this template to a blog post the whole sidebar ends up at the bottom of the page. You can see it in action on this page : https://softmag.onvaseformer.fr/le-savoir-faire-et-le-savoir-etre-en-entreprise/
Any idea why this is happening and how I can fix it ?
Thanks for your help !
Hello !
Please note that all the cloud library templates are fully editable using the tagDiv Composer as you can see here: https://www.screencast.com/t/5OP6mN6VO9 You can edit the ROW and use the elements from tagDiv Composer to create your row. In order to import the sidebar from widgets you will have to use the widgets sidebar as you can see here: https://www.screencast.com/t/8qJZJ2hov6l
Hello !
