Sidebar Problem
Hello
In my sidebar options there is only one last posts https://prnt.sc/ujgmp2
however last post in my post shown 2 times how can i solve that? https://prnt.sc/ujgnaw
Please make sure that you are not using any plugins that can interfere with the sidebar, make a test, let only the theme plugins (tagDiv plugins) activate and check to see the results.
If the problem persists, please provide me a link where I can check this situation.
yok can check it
  • This reply was modified 5 years by Calin.
I just checked your sidebar and on it are set two elements -> https://i.imgur.com/MkDdO97.png please check all your sidebar and if there is still a problem, please try above steps and disable all plugins.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login. We will take a look. Include a link to this topic in the email.
i sent email can you please delete my urls from this thread
