Sidebar problem
How can I make everything aligned. I want image and text to come in vertical aligned. Like this post carousel.
http://i.imgur.com/h56HcXe.png?1
also my excerpt is not working right please help.
site: http://www.thenerdmag.com
I’m not sure I understand, do you want to re-arrange the sidebar content as an carousel layout? If so you will have to re-design and style the sidebar as this was not built to work like that, you will need custom work for this and we cannot offer custom work as we work hard on the development, updates, fixes and support. You can always get a freelancer from sites like: http://studio.envato.com/ if you don’t know how to do it yourself.
What kind of issues do you have with the excerpt?
Please let me know!
Thnaks
I am unable to adjust the excerpt length of the blocks. When I change to letters everything on the homepage get restricted to 50 words.
Also can you tell me about Schema support. Which type of content have schema support right now. Thanks in advance.
Regarding the excerpt you can change it from theme panel for each module as you like. Leave the excerpt length on words and then change it depending by module, I have tested this and found no issue with it, work fine for both cases (words/letters), just chose the excerpt type and then the length on each module.
If you like, you can also change the excerpt for each post by adding it into the excerpt field in post editing panel: http://screencast.com/t/dOisV5bq
You can document about this here: http://schema.org/
Here are the files which have schema support: http://screencast.com/t/ahVy1JZ71Q You can search for schema.org on each file and see how it’s added.
Also noticed that the links on slider don’t work, please check this topic for this: https://forum.tagdiv.com/topic/big-slider-links-dont-work/#post-20238
  • This reply was modified 12 years by Lucian.
